Need help with rear speakers ...
1: Remove the seat belt. Pop off the cover and unscrew the start bit bolt that holds it on.
2: Remove the "Airbag" plastic piece and remove the one screw.
3: Remove the tab at the lower rear corner.
4: Go around the outsides with a tool and poping out the tabs as you go. You will most likely need something to hold back the weather stripping and push the tabs out.
If you're curious about the doors. Its like many have said here already but there is no screw under the window controls like some posts have claimed.
This is for the 2010 f150 XLT regular cab, others may differ.
