fuel leak
Old Nov 6, 2010 | 03:03 PM
fixitdude78's Avatar
fixitdude78
fuel leak
2010 s crew. when filling up, some fuel leaks and runs down the outside of the metal tube coming from the fill neck. the station pump shuts off at tank 'full' so Im not sure if its coming out where the spring loaded door in the neck is or somewhere else.
Old Nov 7, 2010 | 12:08 AM
awq134's Avatar
awq134
I"ve had fuel leak out on me when i try to round off the price to an even amount. I believe i let the pump kick off 3-4 times when it happened. My guess is that the filler neck was full and there is an air vent somewhere in that area that the fuel came out of. it's only happened to me once so i just chalked it up to be trying to squeeze too much gas in the tank.
