A/C Vent Only Temperature Too Warm
Old Nov 6, 2010 | 12:37 PM
budrn's Avatar
budrn
My air conditioning system works well, much better than all the previous Suburbans I owned which never got cold in summer or really warm in winter. 1988,1998, 2000 models all included. My 2001 Limited Excursion without automatic climate control is very satisfactory with the exception of the vent setting, that is, the one that doesn't turn the compressor on. I like to use this frequently year round. In all other vehicles I have owned, this puts out air taken from outside so if the Temp setting is turned to the coldest setting and the air outside is cool or cold, the delivery from the vents should match. On my Ex, the air is always much warmer than it should be. All else works well it just seems like when on vent, the air is being warmed somehow between outside and vent delivery. Ideas?
Old Nov 6, 2010 | 04:59 PM
IanR's Avatar
IanR
Check out this link as it has some information for you. It tells you how to tell if you have a water shut off valve. Hope this helps you out. Ian http://www.dieselsite.com/index.asp?...S&Category=578
Old Nov 6, 2010 | 08:56 PM
Beau Bo's Avatar
Beau Bo
I noticed the same thing too. 65 deg outside and the vent is blowing warm air with the temp control all the way to cold...
3006ROCKS
22
Jan 21, 2018 02:49 PM
VADER2004
Nov 4, 2014 07:06 PM
2003xcrsn4x4
May 29, 2014 03:27 AM
isellrivets
Oct 1, 2012 05:49 AM
