2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Earlier wheels?
Old 07-12-2010, 10:04 AM
gpfarrell's Avatar
gpfarrell
gpfarrell is offline
Earlier wheels?
Can I use wheels from an '05 Navigator on my '07 Navi L?
I know I'll need to add TPMS sensors to them.
My Navi has 20"s and I'd like to step down to 18"s for winter wheels & tires. I found a set of earlier wheels but can't find a straight answer on swapping them.
Does anybody know about some of the wheels have 12mm holes and some having 14mm holes?
Thanks!
Old 07-12-2010, 12:15 PM
berry1234's Avatar
berry1234
berry1234 is offline
The brakes changed and take up a lot of space. I don't think they will fit but I would check it out.
Old 11-15-2010, 07:49 PM
gpfarrell's Avatar
gpfarrell
I won't guarantee it, but after checking lots of places it seems any late model Ford 6-bolt 17", 18" or 20" wheel should fit. Lots of Expys come standard with 17" wheels, as do lots of F150s.
2004 seems to be a year that shows up often for interchanges... but if it's its a recent 6-bolt Ford wheel it should be fine.
Old 11-16-2010, 12:27 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
yes
2003+ Expy/Navi 100% interchange
2004+ F-150/Mark Lt 100% interchange
be careful with some of the 2005-2006 Navi rims. There was a run where the inner hub diameter was a hair too small. Several F-150 guys got their Navi rims stuck on the rear hubs and had to beat the rims off.
otherwise, the rims between the years listed above interchange 100% between Expy/Navi/F-150/Mark Lt.
btw, 17" is the smallest rim you can use. The brake caliper won't let a 16" rim clear without some serious offset and/or shaving. So any OEM 17/18/20/22/23" rim will work fine for you.
porthole
6.7L Power Stroke Diesel
05-16-2012 06:34 PM
tj90
1997 - 2003 F150
12-14-2010 07:41 AM
Greywolf
General Automotive Discussion
05-13-2009 08:36 PM
Quick Reply: Earlier wheels?
