Earlier wheels?
Can I use wheels from an '05 Navigator on my '07 Navi L?
I know I'll need to add TPMS sensors to them. My Navi has 20"s and I'd like to step down to 18"s for winter wheels & tires. I found a set of earlier wheels but can't find a straight answer on swapping them. Does anybody know about some of the wheels have 12mm holes and some having 14mm holes? Thanks! |
The brakes changed and take up a lot of space. I don't think they will fit but I would check it out.
I won't guarantee it, but after checking lots of places it seems any late model Ford 6-bolt 17", 18" or 20" wheel should fit. Lots of Expys come standard with 17" wheels, as do lots of F150s.
2004 seems to be a year that shows up often for interchanges... but if it's its a recent 6-bolt Ford wheel it should be fine. |
yes
2003+ Expy/Navi 100% interchange 2004+ F-150/Mark Lt 100% interchange be careful with some of the 2005-2006 Navi rims. There was a run where the inner hub diameter was a hair too small. Several F-150 guys got their Navi rims stuck on the rear hubs and had to beat the rims off. otherwise, the rims between the years listed above interchange 100% between Expy/Navi/F-150/Mark Lt. btw, 17" is the smallest rim you can use. The brake caliper won't let a 16" rim clear without some serious offset and/or shaving. So any OEM 17/18/20/22/23" rim will work fine for you. |
