Sponsored by: Real Truck
2004 4x4 front rotor replacement
Old Nov 6, 2010 | 04:32 AM
MOC's Avatar
MOC
I have a 2004 4x4 with a bad front rotor,before i get started i would like to know what i am in for and what tools and parts i need before i jack it up then have to run to the parts store.
Old Nov 6, 2010 | 09:21 AM
Rugby3's Avatar
Rugby3
You will need to replace both front rotors not just the bad one, always in pairs.
You only need to pull the caliper/mounting bracket off to replace the rotor. 21MM, 17MM socket will do the trick. It takes longer to put it on stands and remove the wheel than it does to get the rotors off. Very easy job.
Old Nov 6, 2010 | 11:43 PM
wallz's Avatar
wallz
Here is a good link for future ref. or if you haven't done the job yet. Welcome to guzzle's Powerslot/Hawk pads brake Maintenance Web Page
Did mine today. Only took1.5 hrs from start to finish.
M88
Feb 23, 2022 06:24 PM
blueoval65
Aug 11, 2016 09:18 AM
BolognaBlake
Jun 18, 2016 06:51 AM
Fordperson
Mar 28, 2016 07:30 AM
cyberprop UK
Jun 4, 2015 05:39 AM
