Another zf swap
Old 11-05-2010, 08:28 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Another zf swap
I know this has been covered but i cant find **** w the search.
my brother bought a 92 302 5 speed truck w a trans only had 5th or reverse.
but he has a 90 F350 parts truck w a 351 and a ZF.
What all needs to be done to swap the zf in front of the 302
Old 11-05-2010, 09:03 PM
fordman1090's Avatar
fordman1090
fordman1090 is offline
all he needs is the trans and the shifter on top. He will probubly need to have the drive shaft modified to fit right. The zf has a fixed output yoke and depending on the wheelbase of your brothers truck will determine what needs to be done.
If he has a longer wheelbase with a 2 piece drive shaft then the front one will need to be lengthened so that the front shaft reaches the yoke. And if its a short wheelbase with a single shaft it will need to have a shaft with a slip joint in it made.
Good Luck with the swap, ya'll will love the zf. Its a much better tranny.
Let me know if yall have any more questions, iv done it and researched every area of it so im sure i can help you out.
Old 11-05-2010, 09:10 PM
fordman1090
i just though of this, if he has the entire donor truck. he might be able to take the front of the 2 piece shaft in the f350, and use it with the rear piece of the shaft already in the f150. I believe that the that will work as long as the trucks are of a similar wheelbase. Might as well try it. if they both have single shaft you might be golden, all you would need is a conversion u-joint that takes the 1350 u-joint in the f350 shaft and converts to a 1310 u-joint in the f150 axle.
Sorry for all the info, but i hope it helps.
Old 11-05-2010, 10:14 PM
fairlane68's Avatar
fairlane68
fairlane68 is offline
I've never seen a tranny in front of an engine...seen lots of them behind them though.
EDIT: Yes, the search here sucks. You'll find more here if you use google.
Old 11-06-2010, 04:49 AM
Diesel_Brad
IIRC Both the 92 F150 4wd and the 90 F350 4wd have a slip yolk at the back of the tcase and a fixed yolk in the front. Are the mazda and zf differnt lengths?
Old 11-06-2010, 06:22 AM
RedXL's Avatar
RedXL
RedXL is offline
The Mazda and the ZF are the exact same length and to do this is basically only a matter of swapping one transmission for the other. I have done it on 2 different trucks. You need to use the F150 trans mount and I always replace the slave cylinder with a new one for an F150 while I'm in there. I once had a slave cylinder go bad and had to pull transfer case and transmission out just to replace the slave so I learned this lesson the hard way! Also don't forget to look at your clutch and pilot bearing while you're in there. The slave that comes off the ZF looks a little different and just to avoid a possible a compatibility issue I use an F150 slave since it's an F150 slave mastercylinder it's gonna be connected to, but I can't say that the ZF slave won't work...I just never tried it. The bolts holding on the ZF slave are shorter than the bolts holding on the Mazda slave so depending on which one you use you have to use the matching bolts. Good luck with it!
Ray
Old 11-06-2010, 07:19 AM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
The master cylinder piston diameters were the same size across the f-series but changed in 93 or 94, so you can use the ZF slave with the F150 master cylinder as long as both master and slave are for the same year truck.
Old 11-06-2010, 03:31 PM
Diesel_Brad
Ok. Thanks guys
Old 11-06-2010, 03:48 PM
fordman1090
Ok, that makes sense. If its a 4x4, they are both slip yoke. I was thinking 2wd. But, even if they are both 4x4, the zf is still gonna be shorter. The rear tranny mount is the same, but the tail housing is shorter.
Like RED was saying, replace the slave while your in there. It should come with a new throwout bearing. I would also suggest doing the clutch while your in there, and also turn the flywheel. It doesnt cost much and will help save the new clutch and make it engage smoothly.
John_0063
11-30-2016 10:25 AM
Poorboy1967
09-07-2016 04:53 PM
brad_97stroker
06-04-2014 04:22 AM
swampthang
01-01-2014 09:16 AM
ozzy460
02-23-2011 08:27 PM
Quick Reply: Another zf swap
