wiper problems
Old Nov 4, 2010 | 11:18 PM
pvine's Avatar
pvine
wiper problems
Hello all, I can't get my wipers to work with the switch. I've tried three other junkyard switches that have the same result, the motor won’t turn on, but if I remove the switch and make a jumper wire from the hot post the motor works fine. Is it the switches or could my wiper motor be grounded out and shorting out the switches? I’m at a loose on this one, any help would be great. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Old Nov 4, 2010 | 11:59 PM
fmc400's Avatar
fmc400
MSEE
Are the switches you've been using for an intermittent or standard wiper setup?
Old Nov 5, 2010 | 12:11 AM
pvine's Avatar
pvine
I believe they were all intermittent.
Old Nov 5, 2010 | 12:54 AM
fmc400's Avatar
fmc400
MSEE
I would try replacing the governor with a spare.
Old Nov 5, 2010 | 01:04 AM
twisted84toyota's Avatar
twisted84toyota
Mine has an issue with the ground tab on the motor itself it has broken or came apart at some time. I have a soda can wedged in between the motor and the firewall so it will make contact. I have a new motor but had to find time to change it out!
Old Nov 5, 2010 | 01:14 AM
pvine's Avatar
pvine
My understanding, correct me if I'm wrong, is that the switch has to be grounded to work..and i have tried that but didn't help. Would the motor not being grounded give me this problem? I have tried everything i can think of, maybe I'm not thinking outside the box. LOL
Old Nov 19, 2010 | 10:51 AM
pvine's Avatar
pvine
the switches were not intermittent, however i fixed the problem with a wiper motor off of a 77' and a intermittent switch and governor off of what i believe is a 83'. problem solved and now i have intermittent wipers, i guess the old motor was frying the switches, this old pasture rig is coming to life.
thanks guys
