Cost of Head Gaskets & ARP Studs
Old 02-26-2014, 07:14 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is online now
Originally Posted by Misky6.0
I thought black onyz gaskets were a bad choice, use only ford oem head gaskets! Confused?
Sent from my Sprint PC36100 using IB AutoGroup
That is correct!
  #47
Old 02-26-2014, 07:15 AM
Snowseeker's Avatar
Snowseeker
Originally Posted by LivingLarge
Andy, does that make you a stud for hire?
HAha, need a stud to install your studs?
  #48
Old 02-27-2014, 09:11 PM
cornstar6207's Avatar
cornstar6207
cornstar6207 is offline
Hey Matty, where in Wis. are you? I may be looking for 6.0 work to be done.
  #49
Old 02-27-2014, 09:48 PM
matty169's Avatar
matty169
matty169 is offline
Green bay, wi....
  #50
Old 02-28-2014, 05:17 AM
Mcrafty1's Avatar
Mcrafty1
Mcrafty1 is offline
Originally Posted by JBSIXGUNS
My shop is doing it for $3663.32 that includes all parts, and labor, for arp studs, black onyx gaskets, new oil cooler, egr delete, sct tuner, all fluids changed, turbo cleaned, and a pinion seal replaced,
Black Onyx gaskets are a definite weak point, That is if we can believe anything we read here on this site..........I'd seriously consider spending the additional money and staying with the Ford OEM gaskets...........or at least search it out here before you decide.JMHO
FWIW, I personally have no experience with Black Onyx gaskets but I do follow this site and have yet to find a positive statement in their defense....just sayin'
  #51
Old 02-28-2014, 07:16 AM
Snowseeker's Avatar
Snowseeker
The black onyx coating comes off the gaskets with oil. Honda uses the same coating and it causes oil leaks in the corners of the gaskets all the time.
Personally I don't trust any coating on a metal gasket and use my own, have been for many many years now without a single failure.
  #52
Old 03-25-2014, 10:02 PM
Champer11's Avatar
Champer11
Champer11 is offline
Originally Posted by matty169
Green bay, wi....
Know anyone (or shops) near Minneapolis?
We'll be out in Green Bay (door county) the week of memorial day but I'd rather have it done BEFORE I tow our camper out there.
  #53
Old 03-26-2014, 05:53 AM
KDAVID1's Avatar
KDAVID1
KDAVID1 is offline
Are those copper? Cant tell on the phone. Do you make these?
  #54
Old 03-26-2014, 06:12 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
That's copper coat. It's a spray on application.
  #55
Old 03-26-2014, 07:54 AM
Snowseeker's Avatar
Snowseeker
^ that is correct. Permatex copper spray. I had a car in the shop once (4 cylinder turbo car) that kept blowing coolant at WOT down the track. ARP studs torqued to nearly twice the OEM head bolt specs, new gaskets, over and over again coolant spraying out under full boost. After copper spraying the USED gasket no more problems! I believe the customer was just over 40psi of boost.
  #56
Old 03-26-2014, 12:20 PM
KIDkiser's Avatar
KIDkiser
KIDkiser is offline
Would it be a good idea to put something like copper spray on our gaskets,I know my engine builder used to put something on nitrous and turbo charged gaskets mainly around the water passages but I can't remember the name of it.
  #57
Old 03-26-2014, 12:26 PM
npccpartsman
Gasket Sealants : Permatex® Copper Spray-A-Gasket® Hi-Temp Sealant
  #58
Old 03-26-2014, 12:28 PM
KIDkiser's Avatar
KIDkiser
KIDkiser is offline
It seems like the stuff he used was called yamboseal or something like that.
  #59
Old 03-26-2014, 04:19 PM
Snowseeker's Avatar
Snowseeker
Another common one is hondabond for exactly what you mentioned and I have used it a well for those same things. It expands with heat to seal better.
  #60
Old 03-26-2014, 05:18 PM
KIDkiser's Avatar
KIDkiser
KIDkiser is offline
So should we put this stuff on our 6.0's or just put the gaskets on dry?
Quick Reply: Cost of Head Gaskets & ARP Studs
