2011 Fog lights, Whats the deal?
#46
Hello all, I'm new to FTE but have always been a fan. I;m hoping you guys can help me with a OEM Fog Light kit install on a 2012 XL F 250. I recieved the oem kit today and it has a Body control Module (BCM)included in the kit and the instructions are saying that I need a vehicle communication module (VCM) and Integrated Diagnostic System (IDS) software with appropriate hardware or equivalent scan tool. I'm a pretty capable mech and can do the install but this has stumped me.
Input is greatly appreciated on this problem...
Check this thread for more info:
https://www.ford-trucks.com/forums/1...ould-i-be.html
#47
Welcome to FTE!
#48
#50
Ease of the OEM foglight depends on the Truck. My XL had already been programed with the power group and had the wiring. So all I did was put in the lights and a new headlight switch. Turned the ignition to the on position and all was good. The fogs will not work without the ignition turned on. On an XL without the power group, you will need to either toggle switch them or have a dealer do the install.
Hope this helps...
Hope this helps...
#52
You can get the swith for headlights w/ fog light feature. You don't need to have the sensor activated switch. Still manual but with the fog light switch integrated. XLT should be plug and play..
troverman
2015 - 2020 F150
18
12-03-2016 07:17 AM
