Dana 50 Spindle
Old Nov 4, 2010 | 02:01 PM
JCaseF250's Avatar
JCaseF250
Arrow Dana 50 Spindle
My Truck: 93 F250 4WD 5.8L. I've been reading a lot of posts, but nothing seems to cover my question. While removing Passenger Side Front Spindle, I noticed that part of the threads were stripped. My question is, does this spindle need to be replaced, or will it be ok? I didn't finish removing bearings, so that I could better show position in a picture. Thanks for any help with this!
Old Nov 4, 2010 | 02:51 PM
thechief66's Avatar
thechief66
The nut that threads on there is what holds the wheel bearings in place-hence it holds the wheel on the truck. Replace it!!
Old Nov 4, 2010 | 04:25 PM
JCaseF250's Avatar
JCaseF250
Thanks for your quick response! I agree that it should be replaced. However, I have not had any luck locating where to get one!
Also, I should have been more specific in my original post. I would like to clarify that the threads are stripped to the outside of where the spindle nut goes, so the spindle nut DOES tighten and hold the wheel bearing in place. I was wondering if it would be ok to use it like that until I find a new spindle.
Any response to this, or where I can find a new spindle?
Old Nov 4, 2010 | 04:48 PM
donniezyea's Avatar
donniezyea
i got two of those babys! if you need one let me know otherwise there on ebay just make sure you get the dana 50 and not the 44hd version!!! Deff replace it thats your life right there....
Old Nov 4, 2010 | 09:15 PM
garyed08's Avatar
garyed08
seen one come apart before. BAD ACCIDENT!!! Driver was killed. REPLACE REPLACE REPLACE!!!!! Don't put your life on the line
Old Nov 5, 2010 | 10:54 AM
PsRumors's Avatar
PsRumors
I replied to my add in which you asked if I still had these available. I do, both of them.
Old Nov 5, 2010 | 01:12 PM
Diesel_Brad's Avatar
Diesel_Brad
Any junk yard will have them
Red Ford Truck
Ontario Chapter
39
Oct 26, 2012 06:36 PM
duphofff
16
Jul 27, 2010 02:43 PM
morgan867
2009 - 2014 F150
56
Jan 1, 2009 02:59 PM
ExcursionMan
Jun 17, 2008 03:03 PM
fordloverf2501970
Iowa Chapter
19
Aug 31, 2004 06:40 PM
