I noticed some corrosion on the terminals when changing the fuel filter. Never taken the truck off the batteries. Question I have is there a certain order or process that they need to be removed so I can clean the terminals. Or should I leave one battery attached while I clean the other and vise versus. Sorry for the stupid question but first time 7.3 owner.
Just keep in mind that if you unhook the positive battery post on the battery that has the second battery cable running through it, it's energized with 12v. in case you touch the connection against a metal ground... I found that out once.
The fellas above have you going.
DO NOT apologize for asking questions here.....There is NOT a dumb question.We are all here to learn and you have to ask.
Good luck
