new mod help
Old Nov 4, 2010 | 12:37 AM
7.3bo-ti-etr's Avatar
7.3bo-ti-etr
new mod help
Ok so tomorrow I'm tackling the hutch, harpoon, fuel pump helper, and pre pump filter. So my question is where is the best place to buy the pre pump filter and the helper pump.
Old Nov 4, 2010 | 12:51 AM
7.3bo-ti-etr
I'm looking for a 2 micron pre-pump filer and a Carter P4070 electric fuel pump. I'm just not sure where to find them. Please help.
Old Nov 4, 2010 | 12:56 AM
PaysonPSD's Avatar
PaysonPSD
This is what I use for a pre-pump filter. Napa has one exactly like it but I don't have the part number right now but they can cross reference the Baldwin number.
I have no advice about a lift pump because I have never installed one. Did you Google the Carter pump. Some change store auto parts places carry Carter.
Old Nov 4, 2010 | 01:07 AM
7.3bo-ti-etr
Not yet I'm doing all this from my phone. PC to a crap on me. IV been looking at this site for the pump
http://www.guzzle7pt3.com/pump.php
And this one for the hutch/pre filter
http://www.guzzle7pt3.com/hutch.php
Old Nov 4, 2010 | 06:48 AM
Ponyboychris's Avatar
Ponyboychris
Welcome to guzzle's Helper/Lift pump Web Page
Welcome to guzzle's In-tank Hutch Mod Web Page
I'd call Bob directly - He run's this business: Replacement O-rings for Ford Diesel Engines
He would know where he purchased this stuff.
Old Nov 4, 2010 | 07:19 AM
riverrat41's Avatar
riverrat41
I use the same filter as Robin....They work good and you can inspect them often.
Old Nov 4, 2010 | 08:54 AM
Ponyboychris
Silly question but is there any harm in installing a pre-pump filter without doing the in-tank mods? Will there be too much restriction? One of these days, I'll drop my tank and gitter done but was just wondering?
Old Nov 4, 2010 | 10:33 AM
woodnthings's Avatar
woodnthings
Can't really hurt since the in-tank mod just removes the mixing chamber. The only restrictions that the mixing chamber will have is on the return fuel from the filter. The screens are there to catch anything in the return fluid as it is unfiltered from the fuel bowl. The screens do collect quite a bit of debris too.
Old Nov 4, 2010 | 10:40 AM
woodnthings
I just searched P4070 and found the pump available at Jeg's, Summit, and Napa. You should be able to call a Napa store and if they don't have it in stock, they can order it. Brice varies from $75-$85
Napa calls is a NFP P4070 (Napa Fuel Pump)
Old Nov 6, 2010 | 09:25 AM
7.3bo-ti-etr
Is a 35gph @ 7psi to low for the helper pump
Old Nov 6, 2010 | 09:36 AM
damicofuel's Avatar
damicofuel
I mounted a spin-on base under the truck and have a 10 micron filter with drain petcock on it, filter is large enough to only have to change anually. IMO, 2 micron is pretty small for winter climates!
Old Nov 6, 2010 | 05:36 PM
7.3bo-ti-etr
All done only took 2 hours
Old Nov 6, 2010 | 07:23 PM
woodnthings
Did you get the helper pump?
Old Nov 6, 2010 | 08:26 PM
7.3bo-ti-etr
Not yet Napa had to order it $75 not to bad
Old Nov 17, 2013 | 05:05 PM
KennySpencer's Avatar
KennySpencer
Was it ever determined if this type of pump would be enough?
