Sponsored by: Real Truck
This could have been bad...
Old Nov 4, 2010 | 12:22 AM
them_goods's Avatar
them_goods
Question This could have been bad...
Today I took my F350 6.0L to work, when I got there I noticed a small clutch plate on the ground in front of the truck. I picked it up, it was hot... so it had just fallen off, strange. I am really lucky this plate didn't fall of on the freeway, it could have killed someone.
My question is will the pulley stay intact for another week of use until I can get it into the shop or will the whole AC compressor disintegrate, along with the front of the 6.0L motor.
Old Nov 4, 2010 | 07:37 AM
Tom's Avatar
Tom
Good question, does the A/C compressor make a lot of noise when not in use?
I'd suggest that it's probably fine but I am not sure how the clutch operates. I assume, though, that you have a regular nut holding the pulley on just like all the other ones.
Old Nov 4, 2010 | 07:45 AM
89LX306's Avatar
89LX306
I don't know where the AC compressor is located on the 6.0, but if it is easy to get to you should be able to swap it out in about 15 minutes. I know on my 7.3l it is super easy.
If you already lost one piece of it...you will more than likely lose another. Just replace it and be done. It would be a good time to replace your belt too if you've got some miles on it.
Old Nov 4, 2010 | 08:25 AM
i eat hybrids's Avatar
i eat hybrids
The 6.0s ac compressor isnt on the top on the motor, like the 7.3s is. So its gona be time consuming for the OP
