Can Low Fuel tank cause a contribution error?
Stupid me, when I pulled my truck into the garage the low fuel indicator was on, but didn't think anything of it since I have a 50 gallon tank and should have had at least 5 to 7 gallons left in the tank.
Upon finishing, I started her up and expected the long start after experiencing that when I replaced my STP, stand pipes and did an EGR delete a year ago.
But it never stopped running rough - like I had dropped a cylinder.
When I took it out on the road, it was extrememly sluggish and never cleared up. Checked the codes and I had a P0272 - Cylinder #4 contribution error. Thought maybe out of 8 new injectors, I got one bad one so I replaced rubber and copper gaskets on an old one and stuck it in the #4 cylinder and tried again with the same result.
Every time I try to start her, it is a long start and with the same results.
I have torn her back down to put the new injector back in, and was thinking about pulling the head to see if for some reason they messed up the head when they cleaned it up, but before I take it that far, I thought I would put one more post out there to see if may I am just that stupid for not having at least a half a tank of fuel before starting or maybe I am not giving her enought time to get all the air out of her system.
Someone with real experience, please tell me I don't have to pull the head, or at least it is worth a try to put it back together and try something different before I pull the head and take it back to the shop.
Or tell me I'm stupid for not just pulling the heads again and doing it all over again - those Black Onyx gaskets are cheap enough!!!!
How long did you let it run after the overhaul?? Sometimes it takes a while to get air out of the HPO system, but it should still run fairly smooth even with a long crank to start.
For me to take the push rods out, I have to take the head studs nuts off - can I do that without taking them all off to keep even pressure across the head?
Also - Should I replace all 8 push rods in that head, all 16 at the same time or can you replace just one?
I have to admit that this is my first diesel. I have found that it was a bit intimidating at first, but patience and following directions, whether that be from experienced people like yourself or the service manual, have always paid off, and I tend to lead toward experience over the service manual, although there have not been many instances where they have differed.
This is the first time that I have done something to the truck that has resulted in unsatisfactory results.
The reason that I am here is because I was going to replace the old injector with the new one anyway since there was no diffference, so checking the pushrod since I am right there shouldnt be an issue. The real question is, should I release all of the head stud nuts or can I just release the ones that I am going to check and possibly replace.
Also, if it is bent, should I just go ahead and pull the head and replace the valve follower??? And should I just replace that pushrod and follower or both for that cylinder?
Also while I was extracting the pushrods, I noticed that a couple of others seem to have cracks - one that goes almost completely around the pushrod and the other about half way around. both cracks are a little bit below half way down the pushrod, one on the same cylinder as the bent pushrod #4, the other on #2 Cyliinder.
So 2 questions:
When I insert the other pushrods into the slots it feels almost as though there is a seat that they fit in to, but when I insert the new pushrod into the slot that had the bent pushrod, I do not get that feeling - should I replace the Valve Tappet?
Question 2 - I am replacing all of the pushrods on this head regardless, but are these cracks normal? and should I replace the pushrods on the other head?
<!-- / message -->
did you turn the motor pver by hand when you had the heads back on?
I would install the new push tube and go from there. Ive seen lots of rockers get kicked off and more then a few bent push tubes. only see a few cause real damage. .
so far as droping the push tube back in and not feeling the seat goes... i would look inside the hole with a borescope.
Stuck my head down there with my lighted magnet and looked like something thin like a spring or shaved metal was down there. Put the push tube down at a right angle then moved it left and there was a slight reisitance and then it went down and I could feel the seat.
Figured I better take the head off and look.
I would send a pic of the tubes but not sure how to do that. When I click on add image it asks for a URL instead of browsing my computer for the pic. When I figure that out I will send it.
Will get back when I have the head off.
So a question if I may - How do I hand turn the engine? Do I leave the glow plugs out? do I do it before I put the injectors in, and what do I turn? On my gasoline engines, I would put a wrench on the crank and turn without the sparkplugs, but I've never taken the fan and stator out, so I cant get near the front of the crank.
the reason for this is multi folded. first is to make sure every valves moves. second I have found that it helps reduce the damage caused by lifters that wont bleed down by frocing them down slowly by hand. also if something goes wrong its easy to fix whith the engine apart already.
also I do this after torquing the heads to 65ft lbs but prior to yeilding the bolts with the glow plugs out.
questions dont really bother me.
First pic is the push tubes - the top two are ones that have cracks in them. You can barly see them but they are just left of the middle on both. The top one has another smaller one to the right of center.
The bottom on is the one that I obviously put in wrong!
The next one is the valley looking down at the lifters - a bit blurry but you can see the tear on the right - not sure if I have to replace this - Probably should.
I am replacing all of the push tubes for sure, as well as the head gasket as you can see by the picture below, the bent push tube completely tore off the tab
