towing in OD
Old Nov 3, 2010 | 08:38 PM
crazer42's Avatar
crazer42
towing in OD
i was told that i could tow in OD as long as i was on flat ground and my tranny wouldnt be hunting for gears< so i have been doing just that. well as i read some of the posts here i see that people have fried their OD from towing at high speeds is this true, should i be towing with OD turned off?
Old Nov 3, 2010 | 08:55 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
As long as your tranny is not hunting for a gear you can tow in overdrive without worrying about hurting anything. If it starts hunting for a gear while pulling up a hill just hit the OD button until you reach the top.
Old Nov 3, 2010 | 09:01 PM
Ponyboychris's Avatar
Ponyboychris
I try to keep the tranny in the 1700-2000 RPM range and yes I tow in OD all the time. If it RPM's get too low, the EGT's shoot up and I will kick it out of OD to get it back into that sweet spot. This works on all types of terrain. Now, if I see a hill approaching, I will proactively kick it out of OD to maintain speed and momentum.
Old Nov 3, 2010 | 09:22 PM
woodnthings's Avatar
woodnthings
I also tow in OD. Pretty much following the same steps as Chris explained. The only thing I do is keep the EGT's from hitting the 1150-1200 range with low RPM's. If I am pulling a decent hill I will also kick it down to get the squirrels spooled up, then you will have no problems.
Old Nov 3, 2010 | 09:23 PM
ghig1967's Avatar
ghig1967
I can't speak for the first 88,000 miles of my trucks life.. but for the last 35000 (of which maybe 5000-6000 was towing my 8k 5th wheel) I have towed in OD unless is was "hunting " between gears.. I drive kind of like Chris states.. trying to be proactive when approaching hills.. etc.. When my stock tranny was rebuilt @ BTS.. I can honestly say that my OD & my coast clutches were pretty much shot. I can't say if this is related to anything in particular.. but like mentioned. I towed in OD & used the decel in my DP Tuner all the time when towing.
Old Nov 3, 2010 | 10:03 PM
FTrucker's Avatar
FTrucker
I agree or did what Ponyboy said,
I didnt let the truck get to 1600 rpm's or less in OD, I was towbar-ing my 74 monaco so it's plenty heavy. But just hit the OD off till I got up near 50 mph or 2200 rpm's, somewhere in that range switching the OD on would drop me to 1800 or so. Seemed to haul just fine and I had plenty of hills and such.
FTrucker
Old Nov 3, 2010 | 11:19 PM
blacksoot25's Avatar
blacksoot25
I do like ftrucker said around town I have it off but once I hit 50ish I click it on might not be right but my town is populated with stop lights but open roads and freeways I am in od
Old Nov 4, 2010 | 12:26 AM
kx450frider617's Avatar
kx450frider617
With our 8k pound toy hauler we tow with OD off just to cruise at 60. It seems when we put OD on we have to run at 70+mph or it lugs which sucks on CA interstate with a 55 speed limit while towing. Just tow in the sweet spot.
Old Nov 4, 2010 | 01:32 AM
RKern's Avatar
RKern
I frequently pull a horse trailer that weighs around 26,000 which includes the truck. I never turn the OD off unless the truck is hunting for gears which occurs when starting up a hill or mountain. In normal driving with out towing I never turn the OD button off. I change tranny fluid, filter, torque converter filter and transfer case every 30,000 miles. When I pull my hay trailer through fields and some hiway I have the OD in the off position the entire time. I have 188,000 on truck and tranny. I am just now putting tran temp gauge and tran cooler from a 6.0.
Old Nov 4, 2010 | 03:26 AM
Shake-N-Bake's Avatar
Shake-N-Bake
There are only 2 reasons to turn off overdrive.
  1. To keep the transmission from hunting for gears when climbing hills/mountains
  2. To maximize engine braking when descending grades. (especially true if you are using any type of exhaust brake)
Happy towing!
Patton531
May 17, 2013 03:14 PM
ol'yeller
All Things Towing
Oct 18, 2006 10:16 AM
mistakix
Mar 13, 2006 03:44 PM
javi2001
Nov 14, 2004 06:52 PM
F117X
Aug 10, 2000 01:18 PM
