Key Pad Factory Code?
Old Nov 2, 2010 | 08:57 PM
dirtmonkey11's Avatar
dirtmonkey11
I was wondering if there is another way to find out what the factory code for the keypad on the door is. When I bought the truck a while ago, they didn't have the code. Is it somewhere else on the truck, if so where?
Old Nov 2, 2010 | 09:11 PM
xcaliber1972's Avatar
xcaliber1972
look under dash at the security module there should be a number there and it should allow you to set the code to what you want do a search on this forum for the particulars.
Old Nov 2, 2010 | 10:20 PM
alloro's Avatar
alloro
Under the driver's side of the dash (a flashlight helps) and up past the fuse box. Look for a big white sticker with 5 numbers starting with number 1####.
Old Nov 3, 2010 | 11:31 AM
dirtmonkey11
Thanks, I found it and changed the code.
Old Mar 9, 2011 | 04:27 PM
trjeffers's Avatar
trjeffers
where is the security module on a 03 expedition
