turbo reinstall specs
Old Nov 2, 2010 | 04:20 PM
szotty's Avatar
szotty
i have looked and couldn't find my answer what is sequence and lbs i torque the pedistal to block and turbo to pedisal and how easy to replace the ebv orings im getting with my oring kit i ordered, also what do i lube orings with grease/ vasoline/ or oil when insalling
Old Nov 2, 2010 | 05:43 PM
Ponyboychris's Avatar
Ponyboychris
How about this: http://www.dieselorings.com/docs/Pow...structions.pdf
Old Nov 2, 2010 | 07:14 PM
baja2000's Avatar
baja2000
Reprinted From
http://www.dieselorings.com/index.ph...&cat=9&group=6
Instruction Sheet: None - Turbo must be removed to install these o-rings. Turbo to pedestal torque - 35 - 37 lb-Ft / Pedestal to block torque - 18 lb-ft (per Garrett).
