OT...Kinda
Old Nov 2, 2010 | 09:33 AM
robs01f250's Avatar
robs01f250
OT...Kinda
We have a 2002 dodge 2500 gas and it died while driving yesterday. Wouldn't start back so had it towed home. Battery has 12.5 volts to it and when we try to start it, it is like the battery just goes dead. put the multimeter on it and 12.5 volts when key off, when trying to start it voltage drops to 3.5. Traced the ground cable to the back of alternator and that negative cable isn't grounded. Is this the problem?
Old Nov 2, 2010 | 10:22 AM
Diesel 724's Avatar
Diesel 724
Does it look like it is supposed to be grounded and for some mysterious reason it isnt? If thats the case id ground it off and try. I mean you did trace a ground and found it wasnt grounded... thats my guess.
Old Nov 2, 2010 | 11:25 AM
Wiyr's Avatar
Wiyr
might be the batterys have a couple bad cells.
i had a red top with 3 dead cells and would still start the engine, but started it very slow, volts dropped down to 8.9 while cranking but would show 13.6 after
Old Nov 2, 2010 | 11:34 AM
robs01f250's Avatar
robs01f250
yes the ground comes off the battery and then splits into two ground cables. One grounds to the block and the other to the alternator. The on at the alternator isnt grounded
Old Nov 2, 2010 | 11:43 AM
Mike F250's Avatar
Mike F250
Mines a bit older and lots less electrical. 1960 Dodge D100. I had the same problem. I put a new ground cable on and added one from bat to body and all has been good.
artfuldodger
Jun 21, 2012 07:27 PM
Nice Work Truck
Apr 12, 2012 01:56 PM
innoxen
Jan 3, 2011 06:10 PM
Dodge4Life
Jan 29, 2006 05:16 PM
Jaxor78Ford
Dec 8, 2005 10:25 AM
