quit while running tbc fault
Old Nov 2, 2010 | 09:08 AM
brian_speaks's Avatar
brian_speaks
I changed the fuel filters it ran then just quit how do i get the air out of the lines
Old Nov 2, 2010 | 09:34 AM
69cj's Avatar
69cj
key on/key off 6 times till you hear the ficm quit running each time. If still no start you are probably sucking air and more than likely have an O ring problem at the lower filter. Did you lube the O ring with engine oil or vaseline? Diesel fuel can make the O ring bind. Did you torque the cap after it bottomed out. 25 nm torque. Remember, the O ring does the sealing not the threads.
