Sponsored by: Real Truck
How do I pull a door panel?
Old Feb 26, 2003 | 09:23 AM
Big Red F250 SD's Avatar
Big Red F250 SD
Question How do I pull a door panel?
I need to pull off my passenger door panel to inpect the wires and connections on my power window that works intermittently. Where are the clips? I suppose I could go out and buy the manual, but what fun would that be? Any other helpful tips before I begin? Thank you in advance.
<edit> Oh yeah, it's a 2000 F-250 XLT
Old Feb 26, 2003 | 09:34 AM
ECM's Avatar
ECM
I don'y have power windows so mine is a little different, but I think there is only two screws, one behind the reflector and one under the window switch housing. pull up on the switch housing to access that screw. Then just lift sraight up on the door panel and it should come off.
Old Feb 26, 2003 | 09:35 AM
FortyFords's Avatar
FortyFords
did you chk in FAQ's at the top ?
I thought we put that in there if not it should be put in there!
Rich
Old Feb 26, 2003 | 09:39 AM
Big Red F250 SD
yup, it's in the FAQ section. I usually check it first, but didn't even think to this time. Thank you
