Ignorant to weird electrical problems...
Old Nov 1, 2010 | 05:27 PM
tuffy300's Avatar
tuffy300
my 87 ranger has a slow battery drain and I can't figure it out... When I drive the truck, the battery holds a charge just fine. I can park it for a few hours and it will start right up but if I park it overnight the battery is drained in the morning. I have to disconnect the ground at the battery overnight. With the engine running I can disconnect the battery cable and the engine stays running but the windshield wipers come on at breakneck speed! Even faster than the high setting at the switch. Could it be a ground problem, relay, or what? Any ideas greatly appreciated!
Thanks
Old Nov 1, 2010 | 09:27 PM
Franklin2's Avatar
Franklin2
I suspect you may have a alternator problem. If you don't have a testlight or voltmeter, just unplug the alternator overnight and see if the problem goes away. Parts of the alternator can go bad, and it will still charge, but it will drain the battery also when the engine is off.
Old Nov 2, 2010 | 10:20 AM
Grubbworm's Avatar
Grubbworm
If that doesn't work, I also have some parasitic drain troubleshooting stuff that might help here;
Ford Truck Enthusiasts Forums - Grubbworm's Album: Troubleshooting help, for anyone that needs it.
