FPR SHIM????
Old Oct 30, 2010 | 05:51 PM
usmcdaveII's Avatar
usmcdaveII
FPR SHIM????
So I did this mod using a 4-40 screw and nut. I installed a 0-100 psi liquid filled guage ($18) from SummitRacing. The guage fluctuates about 20 psi. So does everyone take an average and call it good or is 20 psi too much fluctuation (guage bad)? Thanks in advance.
Old Oct 30, 2010 | 06:00 PM
fordpride's Avatar
fordpride
the gauge is going to jump around cause the pump is ran off the cam you want your fuel pressure somewere in the 60/70 psi range
Old Oct 30, 2010 | 06:15 PM
redman84's Avatar
redman84
Not at 10 PSI like mine
