carburator
Old Oct 30, 2010 | 06:46 AM
jeffz's Avatar
jeffz
carburator
Hello, I have a 1980 F-600, 370 cu in Ford with a knuckle boom. The carburator throttle linkage is worn out. This carburator has a set up for a cable operated throttle outside of the truck as well as a foot operated pedal in the truck. Any suggestions on repair or finding a replacement. My mechanic put in a rebuild kit, but says the throttle linkage is shot.
Thanks, JZ
Old Oct 30, 2010 | 08:09 AM
dohc_chump's Avatar
dohc_chump
This space for rent...
I think the junkyard I'm going to has a F-600 still sitting out in the yard. I'll check it out and see if the linkage is still there for you.
Old Oct 30, 2010 | 08:39 AM
jeffz's Avatar
jeffz
Thanks, keep me infomred. It is a 2300 2 barrel holley
