Sponsored by: Real Truck
127000 and falling flat
Old Oct 30, 2010 | 01:30 AM
RonC80's Avatar
RonC80
Hey all
been a while I have a problem My 99 sd 5.4 I have been told is loosing compression. My ebrake is not working anymore and if I am parked on any type of incline my truck creeps forward. I live in the catskill Mt. so to find a flat surface sucks. It Is a manuel trany 5 speed.
Does anyone have any reasons that this could be happening besides compression lose?
Old Oct 30, 2010 | 06:33 AM
ruschejj's Avatar
ruschejj
Well, clutches don't last forever either. If you are parking with it in gear, clutch could slip too.
Old Oct 30, 2010 | 07:08 AM
RonC80's Avatar
RonC80
Never thought of that I would have to say it is the clutch first because I have a funny noise if I push the clutch in all the way to the floor
Thanks ruschejj I will check this and let you know
Thanks Ron
senix's Avatar
senix
Park with it in Reverse. That is usually the best gear, or granny low. If your e-brake is bad then get it repaired.
Diagnose where it does not work. Does it engage? Most likely since you live in the salt part of the country it is rusted somewhere.
Old Oct 30, 2010 | 08:26 PM
RonC80's Avatar
RonC80
I know why the ebrake does not work it is just plane worn out every thing works except the worn out pads.
the truck even moves in low or reverse if it is on a steep enough incline. If I can get a weekend off In the next 2 or so weeks I am planning to do all the brakes. I think I would rather have it be the clutch then a compression problem just sounds cheaper and easier. Either way I have to fix it. I have big plans this tax season for the old girl I am planning on going through her from front to back and freshening her up bushings, bearings, shocks, what ever it needs to make it new again
thanks senix for the advise I will try to keep you all informed on what it all turns out to be. I have to brib my better have for a few min on the computer so when I come up with the appropriate brib I will get back on and tell all
Thanks Ron
