Problems !!!!!
Old Oct 29, 2010 | 06:48 PM
ah1988's Avatar
ah1988
Problems !!!!!
the check engine light is on after, a a/c repair we had at a shop
what could it be?
Old Oct 29, 2010 | 06:53 PM
ah1988's Avatar
ah1988
what could it be?
sorry forgot to add the ac system was hot, after it gave out while going down the road ?
what could the check engine light be triggerd by it wasn't on when we dropped it off at the shop ?(don't want to go back to the shop they were a** holes) !
Old Oct 29, 2010 | 08:01 PM
rodneywar's Avatar
rodneywar
check engine light will be triggered by 2 things the engine overheating or no oil pressure
Old Oct 29, 2010 | 08:13 PM
ah1988's Avatar
ah1988
could the whole ac system being hot overheat the engine ?
Old Oct 29, 2010 | 08:15 PM
polarismuddman's Avatar
polarismuddman
Check codes clicky V
Old Oct 30, 2010 | 12:06 PM
rodneywar's Avatar
rodneywar
these trucks dont have a pcm so no codes to check
Old Oct 30, 2010 | 12:08 PM
rodneywar's Avatar
rodneywar
it is possible also check the temp sensor connections behind the ac on the drivers side head it is possible they have knocked a connector off there are 2 temp sensors
Old Oct 30, 2010 | 02:05 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
thats probably just what happened.
Old Oct 30, 2010 | 02:52 PM
rodneywar's Avatar
rodneywar
it aint hard to knock it off cause one connector it straight up and the other is at a 90 degree
Old Oct 30, 2010 | 06:08 PM
polarismuddman
ha ha ha ha I forgot...this isn't the gasser forum.
Old Oct 30, 2010 | 06:42 PM
ah1988's Avatar
ah1988
could you post a pic of the ac temp thing,have no clue what it looks like or mabey a better description
Old Oct 30, 2010 | 06:47 PM
ah1988's Avatar
ah1988
Thank you for the input,but dont know what sensors look like coul someone mabey post a pic ,or better description please!!!!!!!!
going to pop the hood tomorrow so if there is anything else that could possibly causing the check engine light to come on that i could check
please post it!
Old Oct 30, 2010 | 07:15 PM
FORDF250HDXLT
sure.here's Daves engine:
Old Oct 30, 2010 | 07:19 PM
ah1988's Avatar
ah1988
is this located by the ac compressor ? sorry for being a hard hard head,
I FEEL SOOOOOOOOOO STUPID !
Old Oct 30, 2010 | 07:24 PM
ah1988's Avatar
ah1988
sorry just had to look at pic closer ,
driver side head coming twords rad , Right ?
