Interchangeable fuel pump assemblies?
on
It's not a direct swap but it is possible. You will have to change the hard line section as they are shaped differently for front and back tanks and because the electrical connection is different from early to later models. The parts I'm referring to and thier differences can be seen in the pic below. Making the necessary changes is a little more complicated because the electrical connections go down inside the resovoir to the pump so the whole thing has to come apart, you can't just pull off the hard lines and swap them.
warrenraymond
08-07-2017 01:51 PM
pcurtice
09-18-2016 03:58 PM
Ron94150
15
09-14-2015 02:17 PM
lhutter1
01-15-2013 06:06 PM
