sound proofing
Old Oct 28, 2010 | 03:30 PM
chicagodragon's Avatar
chicagodragon
sound proofing
anybody know or reccommend anythiung to cut down in cab noise? the material origenally on the firewall is long gone and i never noticed how loud it is in my truck until i took a ride in a stock powerestroke?
Old Oct 28, 2010 | 05:55 PM
427 fordman's Avatar
427 fordman
Stereo shops usually handle that crap you can stick on and works pretty good. You'd have to gut your interior and put it over the floor in the cab though...
Old Oct 28, 2010 | 07:45 PM
F350-6's Avatar
F350-6
I did my truck with this The Goods
I also did the inside of the door panels with 2 layers behind the speakers. It made a noticeable difference at first. As in you can hear the improvement over what you've been driving with, but the improvement isn't drastic. Someone who rides in your truck once a month would likely not even notice the difference.
If you do this, you'll need acetone to wipe the metal down to remove the dirt and evaporate off without leaving a film, you'll need a roller to roll the stuff in, you'll need some scissors and a razor knife, and you'll need to wear jeans you plan on throwing away afterward. That butyl stuff creeps out of the seams as you're working and it get's all over you.
Did the wife's truck too. She took pictures
Old Oct 28, 2010 | 07:55 PM
jleal_21's Avatar
jleal_21
about how much did u spend on material?
Old Oct 28, 2010 | 08:08 PM
F350-6's Avatar
F350-6
I don't remember. It's been a couple of years. If you want to do the floor, double it up in a few places, and do the inside of 4 crew cab doors and the back of the cab, it will take more than one roll. If you just cover the floor and back, and install strips inside the doors, you could probably get by with just one roll.
Old Oct 28, 2010 | 10:17 PM
fordpride's Avatar
fordpride
Turn up the stereo up or ear plugs
Old Oct 28, 2010 | 10:29 PM
Brain's 97 Diesel's Avatar
Brain's 97 Diesel
Used to use 'DynaMat' when I did auto body. Would cover the seams w/ metal tape from the HVAC industry. Heat gun & several sized small hard rollers helps to save your fingers and get into the knooks & crannies. Could check w/ local stereo shop, Eastwood, local auto parts store, maybe Best Buy or other stereo chain store. Could poss do spray in bed liner also. Inside the doors is a good idea too.
Old Oct 28, 2010 | 11:41 PM
oldbird1965's Avatar
oldbird1965
Ear plugs and a head set!! George, you trying to drown out the motor noise or your kid?
Old Oct 29, 2010 | 03:03 AM
chicagodragon
stereo sucks, i like peace and quiet sometimes
motor noise. kids ride in the bed
Old Oct 29, 2010 | 10:19 AM
oldbird1965
Ya right, I suppose the wife rides back there too?
Old Oct 29, 2010 | 11:19 AM
Brown Falcon's Avatar
Brown Falcon
That spray on sound deadener made by Lizard Skin is supposed to be pretty good. Kinda like spray in bed liner but for sound purposes.
Old Oct 29, 2010 | 07:37 PM
scatgo's Avatar
scatgo
http://www.sounddeadenershowdown.com/cgi-bin/index.cgi
Old Oct 29, 2010 | 08:16 PM
Midwest Dually's Avatar
Midwest Dually
Another cheap option if a person wants to consider, is Peal N Seal at Home Depot. IIRC in my search, it was very inexpensive. I caught a lot of info that it also works wonderfully in cutting out sound and vibrations, as well as heat.
I think it can be found in the Plumbing section. I want to say it was around $20 and two rolls were needed for a CC.
Old Oct 29, 2010 | 08:40 PM
F350-6's Avatar
F350-6
I'm not impressed with the long term adhesion of Peel & Seel, especially if you get it in any vertical applications. Even on the floor, if the stuff comes loose, it loses much of it's deadening capability. Ice & watershield is another one I've heard of as a cheap alternative. If cheaper really worked as good, or almost as good, don't you think Dynamat and the others would offer something similar as an option?
Also for those of us that live in the South or anywhere it tends to get warm in the summer, asphalt based products can emit an odor as that stuff bakes inside the cab on a sunny day.
Old Sep 14, 2015 | 02:56 PM
webmeister's Avatar
webmeister
F350-6 Real good install on the RAAMMat soundproofing. Does the aluminized surface facing the passengers help with the engine heat at all. Seems like it should be facing the exterior but maybe it wouldn't stick?
I am going to do this but worried I will break a door panel tang and not be able to fix it.
Any thoughts on the overall outcome on this... thanks
