ok so my turn signals quit working about 5 or 6 days ago. i have found the problem just have not had time to fix them. so now about 2 days ago my damn dash lights started flickering very randomly and when they flicker so do my running/clearance lights. so no i am all kinds of stumped. i have replaced the headlight switch and still not fixed. although i can hear a light click noise when they do flicker on and off behind the dash but cannot seem to track it down. does any one have any ideas at all?
ok cool i will look into that. the short tripping the internal circuit breaker sound very likely due to the fact that i have some other wires in the harness that re in very bad shape. and i am going to be replacing them this weekend as soon as i can. thanks guys. i let you know what i find out.
Welcome to the site. Sounds like it could possibly be a short somewhere that is randomly shorting out causing the lights to flicker. I'd look for badly spliced wires or wires where the coating is worn off and shorting out.
ok well the trans is done and fixed now to move on to lighting and braking issues. i hope they go as well or better than the trans. then when those things are fixed i should be good to go for awhile. i hope.
ok another thing. I have replaced the headlight switch with a good one and still have the same clicking noise going on in my headlight switch an it also gets really hot. could it just be that the switch i got for it was bad also?
Check the wire for your gear shift indicator on the column. At some time in the life of my Bronco before I bought it someone had been in there and that wire was pinched. It finally shorted out (took 2 years) and your problems sound just like the PIA problems I went through.
