D66?
Old Oct 27, 2010 | 11:11 PM
1950gmcelc's Avatar
1950gmcelc
D66?
<HR style="COLOR: #d1d1e1" SIZE=1><!-- / icon and title --><!-- message -->I am wondering how well a d66 turbo will work with rosewood stage 1's, a stock <ACRONYM title="High Pressure Oil Pump">hpop</ACRONYM> and no intercooler and no tunning? Later down the road I want to go to a 17* <ACRONYM title="High Pressure Oil Pump">hpop</ACRONYM> and <ACRONYM title="DP Tuner - Down Pipe">dp</ACRONYM> tunes. Right now I am just trying to get the truck up and running and put in the parts that are harder to install when the motor is in the truck.
Old Oct 27, 2010 | 11:50 PM
JamesHajek's Avatar
JamesHajek
It will certainly be better than your stock turbo and its the only drop in option we have.
Old Oct 28, 2010 | 12:45 AM
oldbird1965's Avatar
oldbird1965
I have the D66 but with all my leaks I can't say for sure how well it will do. In another month or so I'll get the leaks plugged up and if I can find this thread I'll let you know.
Old Oct 28, 2010 | 01:50 AM
1950gmcelc's Avatar
1950gmcelc
how will it do with stage 1s and no intercooler or tunes?
Old Oct 28, 2010 | 06:10 AM
fishmanndotcom's Avatar
fishmanndotcom
you wont notice it is there but when you do get tunes and sticks you will know what you have. i had to send my chip in for some reason after i did the turbo (long after the new sticks) and the truck was basically stock. it doesnt respond any noticeably just from the D66.
-cutts-
Old Oct 28, 2010 | 08:21 AM
Brown Falcon's Avatar
Brown Falcon
Not entirely correct...
Comp Turbo makes a modified TP38 turbo that is a direct replacement on our trucks, uses the same 66mm as the D66, and costs quite a bit less. About $850. It utilizes 360* oiling which is much improved over the stock 180*(not sure on exact number) oiling. Basically just like the D66 but cheaper.
I'm planning on going with the Comp TP38 when I upgrade (if I dont' go bigger) with my Stage I's, and adding a intercooler and modded 17* HPOP.
The D66 would do great with Stage I's and no intercooler, but you won't get much more from the injectors without tuning. But when you do get tuning the extra air the D66 flows will help keep EGT's down. But again, you can get the Comp TP38 which is comparable to the D66 for much cheaper.
Old Oct 28, 2010 | 12:14 PM
1950gmcelc's Avatar
1950gmcelc
I actually spoke with comp turbo the other day and they said that there turbo has a stock intake wheel. So basically it is a stock tp38 turbo with a larger exducer. They told me that they had misprint in Diesel Power Mag.
Old Oct 28, 2010 | 01:16 PM
Brown Falcon
Here's what they told me in an email:
Thanks for the inquire this unit comes with an upgraded comp wheel with a larger 360 degree thrust it is designed to flow more and drop EGT’s for towing.
This unit is $900 with a $150 core charge.
Old Oct 28, 2010 | 01:19 PM
Brown Falcon
Good to know...
Old Oct 29, 2010 | 08:48 PM
jg96powerstroker's Avatar
jg96powerstroker
i have the d66 and love it, but i have tunes and injectors,and a 17*hpop, and can make my 37 bark at you!! lol but my buddy has a turbo from ebay, its found on there as a stage III, it is almost the same as my turbo but ported and pollished and 300 bucks cheaper and no core, when you do the swap i would mod my pedistol as well
Old Oct 30, 2010 | 02:41 PM
1950gmcelc's Avatar
1950gmcelc
I had seen those turbos a few months back but can't find them now. Does he have a contact number or website. All I can find now are turbos for superdutys.
Old Oct 30, 2010 | 04:04 PM
Brown Falcon
www.beansdieselperformance.com
Old Oct 30, 2010 | 04:55 PM
jg96powerstroker
they are out of portorico, ill see what i can find, i would have went that way my self had i of known, ill see what i can get and send it back
Old Oct 31, 2010 | 02:49 PM
1950gmcelc's Avatar
1950gmcelc
Cool thanks
Old Oct 31, 2010 | 06:59 PM
Talyn's Avatar
Talyn
boo on the d66. IMO.
