Looking for a good used OEM or and very high quality aftermarket. Does anyone have a lead on a vendor? Have had bad luck with aftermarket lights and mirror quality but these seem to be a tough mirror to find used. Looking for a passenger side tow (dual arm) for a 2002 X. Power, Heat, frt. and rear folding, no signal.
I bought this one off ebay. at the time it was the best deal out there. Quality is good. Looks just like OEM, except it doesnt have the red arrows on the bottom arm when you extend it. I've had it on for about 3 months and no problems. It is heavy and solid, just like the OEM one. Not flimsy.
I know you want to stick with the tow mirrors. If you decide to go with paddles, I'll sell mine to you for a great deal. Power, heated, no turn signal. just throwing it out there.
RBMC Freeride. Thanks for the info. Saw your parting out an X. Do you have a good passengers side rear barn door and what color code? Looking for TK. Also looking for good inturnment cluster for 2002 with close to 145k. Thanks
I have the barn door and the color is Aspen Green Metallic P5. Not sure what TK is? The instrument cluster in my truck currently shows about 145K, but it is incorrect for my truck (my cluster was stolen). Might be willing to swap. What miles does yours show?
TK is a light to medium gray/brown. My cluster shows the correct miles for the truck at 145 kish but the oil press. gauge went bad and always buried to one end of the scale or the other so it would not do you any good.
