Code 171
Old Feb 25, 2003 | 05:33 PM
mike b's Avatar
mike b
Code 171
I got a code 171 bank 1 too lean.What parts do I need to correct this problem?What side is bank 1?The first thing that came to mind was the o2 sensor(s).
Old Feb 25, 2003 | 11:15 PM
Racerguy's Avatar
Racerguy
Code 171
Bank 1 is the side with number 1 cylinder...the passenger's side.
Quite likely the problem is the front O2 sensor.
Anything else that can cause a lean condition on that bank can also set the code though ....such as a misfire, vacuum leak, plugged injector etc.
Old Feb 26, 2003 | 12:43 PM
jamyboy's Avatar
jamyboy
Code 171
Mike B. Have you done any recent work on your EXPO? This could be as simple as a fuel injector electrical connection either shorted or just plain dissconnected! I did a plug and coil pak relacement on my '99 EXPO 5.4 and I got the same code after I was done.....I was heart broken after that huge ordeal.........well I looked around and sure enough I forgot to reconnect a injector connection........problem solved.........
Old Feb 26, 2003 | 05:41 PM
mike b's Avatar
mike b
Code 171
No I havent done any work to it lately.Now I do have a k&n air filter and have heard that the oil from it comes off sometimes and gets on the MAF sensor but that usually trips a code for both cylinder banks so Im going the o2 sensor route first.
Old Feb 26, 2003 | 06:55 PM
Racerguy's Avatar
Racerguy
Code 171
With the K&N I would try cleaning the MAF first for the few minutes it takes. It should affect both banks but stranger things have happened.
Old Feb 26, 2003 | 07:23 PM
mike b's Avatar
mike b
Code 171
What do I clean it with?Ive heard windex and q tip on here.BTW I cleared the light this afternoon and the wife drove it to work 11 miles and it didnt come back on,but I fully expect it to come back on later.
Old Feb 26, 2003 | 07:31 PM
Racerguy's Avatar
Racerguy
Code 171
I clean them with Carb-Medic spray carb cleaner. Be really careful with a Q-Tip as the wires you are cleaning are pretty fragile.
If you do a search on here I'm sure you'll find more detailed instructions on cleaning it.
Mr f250
Feb 21, 2016 11:25 PM
dibzz
Jan 15, 2016 11:46 AM
Tyler Roberts
1997 - 2003 F150
Sep 22, 2014 12:40 AM
pete315
Apr 3, 2014 08:05 PM
johnkirk
Jun 6, 2010 09:36 AM
