Need more help! Please
Old Oct 27, 2010 | 11:33 AM
4inchlovin's Avatar
4inchlovin
Ok so I posted a thread a few weeks ago but it was a combo thread about two different things. Now that I have had surgery and am laying on my back pondering ALOT I need more ideas of what this piece of metal out of my motor could be. It was stuck to the drain plug last oil change. No odd sounds or running rough or DTC's. Also IS it posssible to drop the pan with only undoing the motor mounts and lifting up on the motor. OR do i have to unbolt tranny so on and so fort. As always thank you all for the help and good wishes.
The only ints i have for you is its not aluminium on the account that it is magnetic.
Old Oct 27, 2010 | 11:46 AM
Diesel 724's Avatar
Diesel 724
Well it looks like it belongs to something round. Is it possible its a piece of piston on the bottom?
Old Oct 27, 2010 | 12:07 PM
clintbonnie's Avatar
clintbonnie
That's what I was was thinking too.. I would trace the arc onto a piece of paper and then complete the circle to find the diameter..
You have to pull the engine to remove and replace the pan properly..
Old Oct 27, 2010 | 12:47 PM
Mike F250's Avatar
Mike F250
I had mine done at a dealer under warranty. I was told the mechanic pulled the motor mounts and slid the motor back to get the pan replaced. No leaks after 2 years. I read that you must flip the motor to do it properly so the special sealer used on the pan can cure.
Old Oct 27, 2010 | 12:56 PM
aklim's Avatar
aklim
Basically the tech took the risk. He got paid the full amount for R&R of the motor and flipping it around. If it worked, he profited. If it didn't, well.....
Actually, I think the issue is the oil. It COULD drip and cause problems. You can wipe it down or whatever but it would still be a gamble. I wouldn't myself and if the tech did that, I'd make damn sure it was put in writing that he'd be responsible for any leaks.
Old Oct 27, 2010 | 04:26 PM
Ford79's Avatar
Ford79
Nolan, it sure looks like a piece of bearing to me. Doesn't look thick enough to be part of a piston skirt, and the pistons are made of aluminum that wouldn't stick to a magnet.
As far as removing ther pan, I believe engine removal is the best way to go about it.
Old Oct 28, 2010 | 11:49 AM
4inchlovin's Avatar
4inchlovin
Ya im pretty sure its bearing also.
Old Nov 2, 2010 | 06:20 PM
hammer65's Avatar
hammer65
Bearings indeed have metal. This is a good explanation.
http://www.cat.com/cda/files/1408425/7/pehp8042.pdf.
Old Nov 3, 2010 | 11:38 AM
4inchlovin's Avatar
4inchlovin
Thanks Hammer this makes a ton of sense especially since my remmaned motor from "ford" was actually rebuilt by CAT
