I Have HAD IT!
Old Oct 28, 2010 | 08:41 AM
nolan62's Avatar
nolan62
I broke 2 junk yard housings when I put a little to much wrist to them. I got the "cheap" unit from O'Reilly's. I checked and the bolts do not go through into the coolant passage so they really don't need sealant. I use a very thin bead of Permatex high temp on the housing and the head. I also use the gasket. Mine sealed fine and doesn't leak but you must let it set over night. Make sure the bolts are not too long and bottoming out on you before the housing it tight.
