How much dielectric grease?
Old Oct 27, 2010 | 08:12 AM
kailor's Avatar
kailor
I ordered new COPs from eBay and wanted to know how much dielectric grease to use in each boot. After loading spring into boot should I fill the boot completely with dielectric grease? My plugs have 45K on them. Would you change the plugs too?
Old Oct 27, 2010 | 11:00 AM
dirtmonkey11's Avatar
dirtmonkey11
Put a good amount in but don't fill the entire boot, you just want enough the go around the top of the plug when it is inserted into the boot.
Old Oct 27, 2010 | 11:08 AM
pgonza2723's Avatar
pgonza2723
Just a little bit on the tip end will be just fine. If you want you can spread a little around the inside of the coil.... Wouldn't worry about changing the plugs till 75k... even though they are designed for 100k service.
Old Oct 27, 2010 | 05:59 PM
orleec's Avatar
orleec
I remember how pita it was to replace the ones under the firewall, so at the very least, replace those two. I would replace all of them if it's me.
Old Oct 27, 2010 | 07:36 PM
alloro's Avatar
alloro
Oh Lord, help me get through these impure thoughts!
Old Oct 27, 2010 | 07:42 PM
alloro's Avatar
alloro
Put in just enough DG to wet the inside of the boot. You do not want to fill it up because everything gets hot and expands; it'll ooze out and make a mess at the bottom of the plug wells.
Being that far into the project I would change the plugs and take comfort in knowing I might not have to touch them for the next 100K miles or so. If however you think you might get rid of the truck before 100K miles, then no I wouldn't go through the trouble of changing them. Of course if you don't change them and the new COPs don't make the engine run better because of a bad spark plug, you'll be kickin' your own butt for not changing them.
hodges710
Modular V8 (4.6L, 5.4L)
Nov 30, 2011 10:04 AM
PEG
1997 - 2003 F150
Feb 25, 2011 01:04 PM
vze2sgxa
Jul 12, 2009 12:42 PM
jjpic
Jun 18, 2009 11:40 AM
JFUSION
Escape & Escape Hybrid
Dec 17, 2006 01:55 PM
