Bronco II Ford Bronco II
gear raito
Old Oct 25, 2010 | 11:04 PM
mudslinging79's Avatar
mudslinging79
gear raito
whats the gear ratio in the rear end of a 87 bronco 2? trying to save some time narrowing it down so i dont have to pull covers and count teeth
Old Oct 26, 2010 | 12:13 AM
mrshorty's Avatar
mrshorty
Ford installed several different gear ratios (3.27 to 4.11 seems to be the range).
If you know it still has the factory gear ratio, you can look at the sticker on the door jamb for the axle code and look that up. Or you can look at the tag bolted to the differential cover (start of the 2nd line of the tag contains the gear ratio).
If you can't be sure that it has the factory gear ratio, then you're going to have to count something. If you don't want to pull the cover and count teeth, try rotating the wheels through one revolution while counting the rotations of the driveshaft.
Old Oct 26, 2010 | 05:00 AM
mdr617's Avatar
mdr617
Or, on the rear axle, and somewhere on the front axle, there is numbers stampped on it. Do you order a catalog from LMC Truck? Well, in there catalog, or on the website, they break down the number for you...really helpfull, they also decode vin numbers and stuff.
Old Oct 26, 2010 | 09:25 AM
Old93junk's Avatar
Old93junk
3.73 is the most common, but 3.45 and 4.10s are out there.
Old Oct 26, 2010 | 10:40 AM
mdr617's Avatar
mdr617
Right, i thought i had a 3.73, but turnes out it came stock with 4.10s and even a front and rear limited slip....got lucky
Old Oct 26, 2010 | 04:49 PM
mudslinging79
ok, 4-10 gears, no limited slip. dang. anyone know what the explorers run gear ratio wise? if im replacing rear ends, may as well upgrade
Old Oct 26, 2010 | 04:58 PM
Old93junk's Avatar
Old93junk
Most 90s Explorers use the soccermom 3.27/ 3.55s, however, I see a 3.73 limited slip listed.
Old Oct 26, 2010 | 05:05 PM
mudslinging79
well looks like i have to order a ring/pinion set, jeggs has them for the ford 8.8, complete with shims, bearings etc for 276.99, anyone know of a better price? the exploder IS 8.8 rear end, right?
Old Oct 27, 2010 | 03:54 AM
mdr617's Avatar
mdr617
that is the same one i was looking at...and prolly a good idea to get all new bearings and stuff too...And i have been wondering, does anyone know where to get a rear diff guard for the stock rear end? The only things i can find are chrome diff covers and some aluminum cover. I am keeping my stock cover, but i want to ad one of those guards that are made of tube stuff....any available??
Old Oct 27, 2010 | 07:07 AM
mudslinging79
for the rear dif cover guard i would ask around at some off road shops. ive seen them, so someone has to make them
