Beginner Quad Rider Advice
If you've riden dirt bikes and even bicycles, it's hard to get used to the fact that you can't lean and turn. All my life I got used to twisting the handlebars and leaning and moving side to side easily.
It's a real culture-shock to get on a 4-wheel ATV (a trike was even worse). Worse, if it has a solid rear axle (which most if not all have), it's a PAIN to turn. You basically have to lean out of the turn so you get the inside rear wheel to lose some traction. The first time I got on a 2-wheel-drive ATV I almost wound up in the ditch because I couldn't turn the darn thing.
Another point: If you are going to use it for ANYTHING utility-wise, get a 4x4. Not only is a 2-wheel drive ATV almost useless for traction (unless you are very experienced), a 4-wheel-drive will allow you to make tight turns without that "leaning out" thing because the front wheels will pull the front of the ATV in the direction you turn.
I used a 4-wheel Honda the last few years, I think it was only a 350, to pull big logs through the woods in Upstate NY using a chain. Darn thing just pulled like crazy. And with 4-wheel-drive, it was a pleasure to maneuver.
Just my $.02's
