Intake Questions
Old Oct 25, 2010 | 09:05 PM
jgavac's Avatar
jgavac
Question Intake Questions
I found a used Edelbrock Performer intake for Ford 351m and 400m, for cheap. First off, will the carb that I have now fit on the intake, and secondly will it provide any sort of power upgrade? It would be installed on a 78 F250 with a 351m, and a Motorcraft 4bbl carb (not sure of the model), 350cfm
Old Oct 26, 2010 | 12:52 AM
cathode's Avatar
cathode
If you have a 4 barrel now, it should work fine although a 350 is pretty small. It will likely be a semi-noticeable upgrade over your stock 2 barrel. Is your 351 completely stock otherwise? If you want to crank it up a bit, a 550 or 600 cfm with the right jetting and a straight up timing set will do wonders if you're all stock now.
Old Oct 26, 2010 | 08:33 AM
jgavac's Avatar
jgavac
Oops I meant to type 650. And the engine was bored 30 over, re-stroked, and high rpm cams w/hydraulic lifters were put in
