On the IPR there is a sleeve held in place with a cheap nut and two wires for the electrical connection. My question is how does this this sleeve pick up the signal or amount of pressure? I only ask because mine fell off. Apparently the nut came loose and the sleeve was dangling by the wires. I am wondering if this is what has been causing my truck to stall out when doing a hole shot. I just did the Hutch Mod and installed a mechanical fuel guage and am getting 60 PSI, so Im guessing my fuel pump is O.K. (or not?) I don't know. Still stalling on a hole shot. Next I will be rebuilding the fuel bowl with deisel O rings new billet FPR housing. Im just throwing money at parts at this point.
The wires just go to an electro-magnetic coil. When current is applied, the resultant magnetism will cause a small plunger to move, moving the position of a poppet valve that allows the high-pressure oil to re-circulate back into the pump, thus controlling the pressure.
That current is supplied by the PCM, which senses the pressure on the driver's head high-pressure oil gallery. It also knows RPM, throttle position, and a host of other things with which it calculates the HPOP pressure necessary to fire the correct amount of fuel to meet the engine's power demands.
Pop
Right Pops , I worded things wrong, I know that the Injector Pressure Regulator is mechanical, its the elecro magnetic coil that fell off. So now that you explained it could that have been the reason for the stalling out on a hole shot?
If the IPR is not operating correctly your truck will run like crap, sometimes no start and sometimes intermittent or erratic behavior. A loose nut (besides the one at the wheel ) on the IPR coil can certainly cause problems.
So Pops is right, and my problem is finally solved. The most amazing thing is I made it all the way home from CO, a good 800 miles, towing my 5er. I guess on one hand lucky, on the other hand just shows how reliable and bullet proof these trucks really are. The big question was any damage done that I don't know about, like injector damage for example.
