302 sluggish in OD
Old Feb 25, 2003 | 09:36 AM
Border3899's Avatar
Border3899
302 sluggish in OD
I've been posting a lot out here lately and i've got one more questions. I recently transplanted my old 91 302 with 165K for an 86 302 with 70K because the engine was going bad on the 91, stuck rings, bad head gasket, the list goes on. Well now that i've got the 86 in there, i wish i had the 91 back...even though the 91 was running poorly i still had more HP and torque than i do with the 86. Better example, when driving down the freeway at 75 in OD the OD will automatically disengage like it doesnt have enough power to cruise at 75 mph, now with my old run down 91 i had no problems cruising at 75 or 80, any one have any ideas as to why this 86 wont cruise in OD very well? I am also only getting 7 mpg with this one and i would have assumed with a solid engine ie...no stuck rings or cracked exhaust manifolds, i would get better than with a run down 91...any help would be great.
Old Feb 25, 2003 | 02:44 PM
macguyver's Avatar
macguyver
302 sluggish in OD
Howdy neighbor,
Has the '86 had anything done to it? Are you using the induction system from the '91? Could be the difference in the cams. How's the timing chain?
Greg
Old Feb 25, 2003 | 03:29 PM
Border3899's Avatar
Border3899
302 sluggish in OD
We had to use the intake from the 91 but for the most part that was it.
Old Feb 25, 2003 | 04:21 PM
EPNCSU2006's Avatar
EPNCSU2006
302 sluggish in OD
Is the timing correct? It sounds sort of like it's not advancing enough. That would cause a lack of power and poor gas mileage. Which computer and sensors are you using, the ones from the 86 or the ones from the 91? Hope this helps.
Old Feb 25, 2003 | 04:54 PM
Border3899's Avatar
Border3899
302 sluggish in OD
I will check the timing on it, as for computer chips we are using the ones from the 86.
Old Feb 25, 2003 | 05:12 PM
Border3899's Avatar
Border3899
302 sluggish in OD
Would a bad O2 sensor cause the bad gas mileage?
