01 Expedition Coolant Flush Location
Old Oct 23, 2010 | 11:03 AM
newbis's Avatar
newbis
I have yet to find a straight answer. There are two hoses coming from my firewall and I'm not sure which to choose to place the tee. I know you're NOT supposed to pick the hose connected to the water pump, but I can't tell where the water pump is located. Since I have a 50/50 shot here, should I splice into hose #2, the one on the right??
Thanks so much in advance!!!
Old Oct 23, 2010 | 01:13 PM
JeffHann74's Avatar
JeffHann74
I didnt use the tee at all. I drained the radiator down, filled with water, added the bottle of flush stuff and let it run for 30 minutes. Drained it down again, pulled thermostat out, put the t-stat with hose back and the disconnected the upper hose where it goes into the radiator. Put the water hose in the degas bottle, started it and let run until clear water started coming out the upper hose. Put it all back together and fill.
Old Oct 23, 2010 | 03:54 PM
alloro's Avatar
alloro
Neither goes to the water pump but #2 is a lot closer.
Old Nov 12, 2010 | 09:31 AM
newbis's Avatar
newbis
I put the T on pipe #2. Flushed per the back side instructions, replaced Tstat using MotorCraft part and have no problems at all. The Tstat I bought from Autozone had a wrong sized gasket so I just went to the dealer. If you ask, they'll give you a customer 10% most of the time. Any little bit helps in this economy.
Old Nov 12, 2010 | 01:52 PM
vze2sgxa's Avatar
vze2sgxa
Did you also remove the block plugs in back of the block, accessed from underneath the vehicle, uses a hex driver to remove it? You'd be surprised how much crap settles back there that can't be flushed completely without opening those. After you drain it dry, replace the plugs with a little bit of red thread-lock on the threads.
Old Nov 27, 2010 | 12:51 PM
newbis's Avatar
newbis
I'll do that next time...thanks!!
Old Jan 3, 2011 | 11:27 AM
makthenif's Avatar
makthenif
so is the #2 hose shown above the heater intake hose? just wondered if this was identified as such.
HEAVY100
80
Nov 17, 2019 01:07 AM
SharkyJ
17
Dec 21, 2015 07:52 PM
RMBC Freeride
Ford Truck Parts for Sale
285
May 28, 2014 05:17 PM
fordktpjoe
May 12, 2012 10:36 PM
DASZU
May 13, 2011 08:12 AM
