clutch linkage question
Old Oct 23, 2010 | 07:10 AM
fire521's Avatar
fire521
ok cal me a *******, 75 f250 4x4 4 speed, took it down to the frame (yes have pictures) and now statring back up have only lost one part so far, and that is in the clutch linkage, it is the part that pushes the release lever on the trans. i have the brackets, and the threaded double nutted part but i think there was one more that went from the threaded part to the release lever i have looked in LMC but cant find it pictured and have no clue what to call it, hopefully one of you can help thanks
Old Oct 23, 2010 | 12:26 PM
Yacomash800's Avatar
Yacomash800
are you looking for the part on the end of the threaded part, that pushes on the fork? or are looking for the part that goes up through the cab up to the clutch pedel?
Old Oct 23, 2010 | 04:46 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by fire521
75 f250 4x4 4 speed, took it down to the frame (yes have pictures) and now starting back up have only lost one part so far, and that is in the clutch linkage.
it is the part that pushes the release lever on the trans. i have the brackets, and the threaded double nutted part (rod) but i think there was one more that went from the threaded part to the release lever.
The clutch release rod is composed of two separate parts.
The threaded rod (D3TZ7521A) which you have, and D3TZ7A504A .. Clutch Rod Extension-the missing part / 3/8" I.D / 9/16" O.D. / 2 23/32" long / Obsolete
WILDCAT FORD L/M in Nicholasville KY has ONE = 859-272-2626.
RAY'S FORD MERCURY in Brandenberg KY has ONE = 270-422-4901.
EARL FLOYD FORD in Carrolton KY has EIGHT = 800-732-2037.
GREEN SALES CO. in Cincinnati OH has TWELVE = 800-543-4959.
There are 72 additional available from FoMoCo dealers and 40 additional available from obsolete parts vendors scattered across the US and in Puerto Rico.
Old Oct 23, 2010 | 11:13 PM
fire521's Avatar
fire521
that would be the part numberdummy....thank you very much
