Rebuild
Old Feb 25, 2003 | 05:46 AM
DEWesson's Avatar
DEWesson
Rebuild
Ok Guys," you that know", I need your help. Need to rebuild E4OD 97 7.3 Tur.Dies Tranny. Have decided on my Torque Converter. What I Need is help in related items that need to be beefed up so Torque Converter doesn't prematurely fatigue or diminish the longevity of tranny job. For instance, what is a sprag, why is a better one beneficial. Bearings, I know a bearing is better than thrush washers, but with all the other stuff in their, what else do I need to beef up. How bout, clutch packs for each gear, are there better clutch packs than OEM. (This is an Automatic w/OD). Now, it gets better, I tow 7 tons at times, (F-250 HD), Can I swap a 350 rear end to take the stress this re-work is going to do that has same gear ratio, or is the F250 HD rear end the same as the 350 rear end. I operate a Foster Home For Children, have 9 horses,cattle, and have to tow a lot, hay for these animals etc. Want this to be my one and only rebuild. Your help, any help comments would be appreciated. Thanks, Danielwesson(No Email Addresses In Posts!)
