Spools do they have ratio #'s
Old Oct 22, 2010 | 09:45 AM
JRS75f100's Avatar
JRS75f100
Question Spools do they have ratio #'s
does anybody know if spools have ratio # dumb question, but how when u look for them they dont say what ratio it is ?????? can anybody help
Old Oct 22, 2010 | 10:54 AM
blackkawi400's Avatar
blackkawi400
The spool just replaces the differential, not the ring or pinion.
You have to unbolt the ring gear from the differential and replace the differential with the spool and bolt the ring gear back on.
This:
Replaces this:
Old Oct 22, 2010 | 10:55 AM
Poison Oil Racing's Avatar
Poison Oil Racing
spools don't but the gears do. You will have a 'case break' at certain gear ratios, meaning that a particular case can only handle up to, say 4:10 gears, and after that you will need a new case because the gears are physically bigger.
Old Oct 22, 2010 | 11:10 AM
JRS75f100's Avatar
JRS75f100
Blackkawi400, thanks for the pics, poison oil racing, great help and info much appreciated that helped out alot thanks fellas, cant wait to get my truck running just started the project, getting as much info as possible before any regrets.
