Today I replace my wheels and for whatever reason I noticed my truck has the old school button on the hub (in front) that you use to lock in 4 wheel drive. In the unlock position the hub spins freely and then ofcourse when you lock it in it doesnt'. Inside I can also do it. The shop said I had never had the truck in 4 wheel drive unless I had locked it in on the hub. This is bull. I don't use the 4 wheel drive much but i know i have at times. Whats this old school button for?? thanks. Herb
Button? Not sure but I think you are talking about the hub itself the locking hub rotates to either "LOCK" or "AUTO" that will be printed on the hub face with ESOF. The "AUTO" allows it to be used on the fly with the turn of the 4x4 selection switch on the dash. the "LOCK" is for when the system has a vacuum failure and you can manually lock the hubs.
When your hub is on auto and you put the truck in 4x4 it is like having a limited slip front end. Your front tires will not always spin at the same speed and sometimes one of the tires might not spin at all. If you put the hubs to lock it is like having posi. The wheels will always spin at the same speed no matter what which will make the truck hop like crazy if you are turning and hit dry pavement. This is mostly used if you are very stuck in snow or mud to keep all the wheels spinning together. Sometimes when i'm plowing very deep snow i have to lock in my hubs or i won't be able to push it.
Sorry, this is simply incorrect.
When the hubs are in auto, the ESOF switch on the dash should lock them automatically when you switch to 4x4. When the hubs are in lock, they are locked.
There is no posi on the front end. It is a simple open differential that works the same way, regardless of the way the hubs are locked.
WOW,that's cool. I've never heard that before. I always thought the manual hubs were just a back-up if you had a vacuum leak or something and your auto hubs didn't work. If this is the case,how does it work? I would think either the hubs would be locked or not but this makes it sound as if there's some sort of locker in the front diff. or something? I learn something new on here every day!!
Manual lock and ESOF do the same thing...they lock the hubs to their respective axle shafts. They have nothing to do with the differential, as Mr. Chamberlain said.
fomoco60, if you're noticing a difference in the way your truck acts it may be that your hubs are not locking when you use the ESOF.
Now THIS makes sense,I was wondering how that could possibly work.
I can only speak from experience since i am not a mechanic but i do know for a fact that the truck acts completely different when i manually lock the hubs. It is harder to turn, it gets much better traction, and can push a whole hell of a lot more snow. As an example.......one day last year i was in a pretty good snow storm that started as ice. I was trying to get up a steep hill coming out of a subdivision onto a main road and no matter how fast i took a run at it i just could not get up this hill (hubs on auto, esof to 4x4 high, and i am positive i had the front tires spinning). I finally got out and put the hubs on lock and first try without much of a run i was at the top of the hill without breaking a sweat. So if you are telling me they do the same thing can you please explain this to me. Is something wrong with my ESOF? I would really love to learn something here because i "thought" i knew what was going on.
If your truck acts differently when cornering with the hubs locked manually than it does when you lock them with the ESOF switch then I'd bet you're hubs aren't locking automatically. Usually that's due to a vacuum leak, often at the hub seals.
Does your heater/air conditioner only blow out defrost when you use the ESOF?
I would say that your at least one of your front hubs is not locking automatically. It is really the only thing that explains what you are experiencing. You said you are sure that your front wheel was spinning. How were you sure unless you were outside of the truck where you could see the wheel spinning?
Attached is an exploded diagram of the front axle. You can see that it is a simple open differential.
As others have said the hub locks have nothing to do with the differential. Try putting the truck in 4X with the switch then crawl underneath and try turning the front drive shaft. If it spins your esof isn't locking in your hubs. If it doesn't spin it may still only be locking one hub. Jack up the front of the truck and spin the shaft. Both tires should spin.
I spend many many hours in my truck while plowing so i would have to say that all of my heater functions are working properly between defrost/floor/vents or i would notice the floor getting cold since i would sometimes be in 4x4 for hours at a time. But i will have to look more closely to find out for sure.
Yes i am sure that i had at least one front wheel spinning by the feel in the steering wheel and the snow flying up in the air when i was basically sitting still because of being stuck.
