1978 - 1996 Big Bronco
front breaks????
Old Oct 21, 2010 | 06:54 PM
bigforddan's Avatar
bigforddan
front breaks????
how do i get my front break disc's off.... i have lock out hubs... do i need to take the lock-out hubs off to get the discs off cuz they need turned really bad....
Old Oct 21, 2010 | 07:09 PM
greystreak92's Avatar
greystreak92
You remove the entire rotor and hub assembly which requires removing the locking hub first. If you need to replace the rotors you can either replace the entire hub and rotor assembly or you can drive out the wheel studs to separate the rotors from the hubs and replace just the rotors and wheel studs. Check out the sponsor of this forum for parts.
Old Oct 21, 2010 | 07:34 PM
bigforddan's Avatar
bigforddan
Originally Posted by greystreak92
You remove the entire rotor and hub assembly which requires removing the locking hub first. If you need to replace the rotors you can either replace the entire hub and rotor assembly or you can drive out the wheel studs to separate the rotors from the hubs and replace just the rotors and wheel studs. Check out the [url=http://broncograveyard.com/]sponsor of this forum[/] for parts.
ok thanks i apprisiate it
