Electrical Problems
Old Oct 21, 2010 | 02:10 PM
csdalrymple's Avatar
csdalrymple
Electrical Problems
I'm having some electrical problems.
1. None of my controls on my steering wheel are working: cruise, horn, and airbag light is flashing. I've checked all fuses.
2. My front gas tank is not working. When I switch it, truck dies. Is their a way to check the pump without removing? Or what's the best way to check?
3. My temp gauge zeros out when I start the truck and never reads.
4. Truck is staggering a bit and small mis fire. I've changed plug wires, plugs, cap, rotor, o2 sensor, and maf sensor. When I unplug the maf sensor, seems to be no change in idol or performance, but check engine light comes on.
Any help is appreciated. Thanks guys!
Old Oct 21, 2010 | 04:26 PM
EPNCSU2006's Avatar
EPNCSU2006
1. Sounds like it is an issue with the clock spring. What year truck and what engine?
2. You can listen for the pump when you first (2 seconds) turn the key to run, or you can ground the fuel pump pin in the diagnostic connector under the hood (as long as it's not OBD-II). I would double check for 12V at the fuel tank connector and if there is 12V, the pump is likely the problem.
3. It's either a broken wire, a failed sender, a poor ground path between the sensor and the engine, or a poor ground path somewhere between the engine and the gauge. Test the wiring and the gauge by momentarily grounding the sender wire with the key on - the gauge should read full "hot." If not, start checking the wiring between the sender and the gauge, along with the gauge itself.
4. Start by checking for codes. It'll either by by jumping the SIG RTN wire to STI wire in the diagnostic connector or an OBD-II scan tool depending on the year of your truck. Any guess at a failing part will be a shot in the dark without some kind of troubleshooting process.
Old Nov 3, 2010 | 04:16 PM
csdalrymple
The truck is a 94 f150 2wd w/ dual tanks. 5.0 engine and e40d transmission. Not getting any codes for check engine. Did fix the clock spring. Now both ebrake and abs light stays on.
Old Nov 3, 2010 | 04:21 PM
csdalrymple
strokin'_tatsch
76
Jun 15, 2018 05:27 AM
teamshadyinc
33
May 2, 2013 09:05 AM
Stewart_H
Feb 1, 2012 11:49 PM
Tom
Jan 23, 2012 09:03 PM
bob52
Engine Swaps
Feb 17, 2008 08:27 AM
