help major brake problem ty
Old Oct 20, 2010 | 12:51 PM
mrwilhelm01's Avatar
mrwilhelm01
hey all i have a 74' ford f350 dually and i checked my fluid in the m/c and the front section was empty and pedal has to be pushed all the way to floor to stop.i filled it up before leaving guys house with truck and when i checked it a few days later its empty again and the front of the m/c is wet looking like its been leaking so i am tryin to figure out my options of what the problem could be as like if its the m/c cover or smethin down further ty
Old Oct 20, 2010 | 02:59 PM
F-250 restorer's Avatar
F-250 restorer
I have a 75 F350. You need to get under your truck with a GOOD flashlight, and physically inspect all your lines for leakage. Check front soft lines for cracks too. I am about to replace mine because of cracks. If you need new ones, order close outs from Rock Auto for half the price. Also, the front section of the mc is the rear brakes, so check behind you wheels for fluid. It could be a wheel cyclinder.
I would R&R the MC. Only about $20 for a rebuilt. But you need to be certain system is not losing fluid elsewhere.
Tip: If you swap out any lines, or mstr, take a little squeeze bottle and gently squirt fluid into the line with only one end attached before reattaching the end you are filling. It saves a lot of time during the bleeding process.
Old Oct 21, 2010 | 12:40 AM
Dugan5150's Avatar
Dugan5150
You might even want to take the wheels off and look inside the drums for wheel cylinder leaks if you don't find any leaks under the truck. They can leak without really showing many signs of leakage outside of the brake drum. btw, F250 Restorer, thanks for the tip about squirting fluid in the brake lines. I'm definitely going to do that next time.
danheit
21
Oct 13, 2013 08:58 PM
prndl
1961 - 1963 F100 Unibody
Dec 27, 2012 06:14 PM
fred_79f250
Jan 12, 2006 01:24 AM
F350SuperCab4x4
20
Aug 8, 2004 12:40 PM
phjbbu
Jul 5, 2002 11:23 AM
