Air filter
Old Oct 20, 2010 | 12:42 PM
tolliewolly's Avatar
tolliewolly
Air filter
Whats the latest on air filters? What do you guys like. I have 82000 on my 6.0 and I have never changed it. I have checked it and it looks good. I know they are expensive but heck at 82,000 miles on an original air filter, thats pretty good!
Just go get a motorcraft? What is everyone else doing these days?
Old Oct 20, 2010 | 01:11 PM
WH 6.0's Avatar
WH 6.0
I would stay with the stock filter. It's really hard to beat the stock set-up and really easy to dust your motor with some of the aftermarket stuff out there.
Old Oct 20, 2010 | 01:14 PM
tolliewolly
just go get a motorcraft or is it any better or worse to get a WIX?
Old Oct 20, 2010 | 01:18 PM
WH 6.0's Avatar
WH 6.0
I would use Motorcraft or Donaldson only. I don't know for sure but word around here is that Donalson is the manuf. for Ford so the Donaldson filter is THE SAME as the Motorcraft but like I said I can't swear to that,just what I've read. I can say that you can't go wrong with the Motorcraft.
Old Oct 20, 2010 | 01:21 PM
69cj's Avatar
69cj
There is a blue and a white one. Get the blue. It's a synthetic material that repels moisture. That is the one that came stock. And yes, Donaldson makes them for Motorcraft.
Old Oct 20, 2010 | 02:08 PM
tolliewolly
alright i will go to the dealership tomorrow or i will check the vendors and supporters on here to see if there is anyone here that sells stock motorcraft items.
Old Oct 20, 2010 | 02:14 PM
dchamberlain's Avatar
dchamberlain
http://www.dieselfiltersonline.com/F...n-Fa-1778.aspx
If your filter minder hasn't moved yet, then your filter is still OK.
Old Oct 20, 2010 | 03:06 PM
tolliewolly
no it hasnt moved but goa its been in there forever!! I mean I feel I am not taking care of it by running one so long.
Old Oct 20, 2010 | 03:28 PM
Cowboy65's Avatar
Cowboy65
The Donaldson filter will hold about 3 pounds of dirt before it needs to be changed. So if you don't do much off road driving the filter will last a long time. Also the filter is reported to stop 99.99% of air borne contaminants which are larger than 1 micron. For reference the human hair is approximately 74 microns in diameter.
Stick with the Donaldson filter.
Old Oct 20, 2010 | 05:01 PM
moebdick's Avatar
moebdick
Push the test button on the filter minder to be sure it's still OK. Also take it off and check it close to be sure it isn't cracked. If it's good, then your filter's still doing its job. Mine made it to 67K before the minder moved to the first blue line. I could have probably let it go a while longer but I just went ahead and changed it.
Old Oct 20, 2010 | 05:15 PM
tolliewolly
WOW!!!!!! I agree! I am sold now!
Old Oct 20, 2010 | 05:21 PM
dchamberlain
I took my filter minder off and sucked on it. The little yellow disk pulled in easily. I assume this means it's still functional. Push the button to release the disk back to it's original position.
Old Oct 21, 2010 | 04:11 PM
tolliewolly
Guys I feel like an idiot but I need help. I got a new filter today but the old one WILL NOT come out. I am pulling so hard that the radiator tank is creaking from the intake line holding against it. I hav done everything except cut it out. How in the heck do you get it out??
Old Oct 21, 2010 | 04:18 PM
npccpartsman's Avatar
npccpartsman
There is a video posted (may be in the tech folder) of a very easy way to remove the filter. Basically you move the small coolant line going from the radiator to the degas bottle, unclamp the intake from both ends, remove the wiring from the filter minder and MAF sensor and lift the whole assembly out. Notice the two prongs on the bottom of the filter that go through rubber grommets, but they should just "slip" out.
Here are some good instructions: http://www.forddoctorsdts.com/articl...icle-06-01.php
Old Oct 21, 2010 | 04:25 PM
moebdick's Avatar
moebdick
I also loosen the first band clamp holding the rear filter housing to the turbo inlet and pull the housing off the inlet tube so it's freer to move around.
Here is the video mentioned by npccpartsman:
http://powerstrokediesel.dealerconne...06/EF_1364.mpg
