drenzer
Old Oct 20, 2010 | 09:09 AM
drenzer's Avatar
drenzer
drenzer
1986 F150 had a leaky wheel cylinder which ran master cylinder dry. I refilled master cylinder, wheel cylinder and washed brakes down with brakekleen and then sanded drum and pads and then bled rear brakes. The pedal seems very hard, brake booster and master cyl. less than a year old. Check valve on booster works good, no leaks that I can hear and plenty of vac. What am I missing.
Old Oct 20, 2010 | 11:07 AM
f100jim's Avatar
f100jim
What exactly is the problem? It sounds like you had a problem, fixed it, and now everything is working fine. Is something still wrong?
Old Oct 20, 2010 | 11:37 AM
drenzer's Avatar
drenzer
F150 brake pedal too hard
The pedal is too hard. It seems like I have a blockage because it's stopping poorly. I did not bleed the master cyl. but did bleed the rears with no problem.
Old Oct 20, 2010 | 09:02 PM
ctubutis's Avatar
ctubutis
Did you replace your wheel cylinders? I hope so.
I don't know how well any brake cleaner will work on removing brake fluid that has soaked
into brake shoes but that's a different issue.
Concerning your pedal, I'm gonna suggest bleeding all 4 wheels, not just half of them
Old Oct 20, 2010 | 09:15 PM
Stangrcr1's Avatar
Stangrcr1
Rebleed ALL the brakes.
Old Oct 21, 2010 | 06:11 AM
drenzer's Avatar
drenzer
you're right about the brake cleaner "brakeleen" found the brake glazed, replaced shoes. Going to bled the whole thing like u suggest starting with master cyl. Thanks
Old Oct 21, 2010 | 09:42 AM
FordNFishinLover's Avatar
FordNFishinLover
Yeah, i would also suggest bleeding all four brakes. Make sure you start with the one furthest away from the master cylinder also.
If your by yourself you can just air bleed them.
Old Oct 21, 2010 | 12:02 PM
drenzer's Avatar
drenzer
gotcha, tks
